[RF module] Transmittance and Reflection Problem
Dear all,
My model is as attched file, in which the blue one represents the dielectric material, SiN with refractive index of 2 (the dielectric material is periodic arranged and infinit long in the y direction) while the yellow region is defined as Air with refractive index of 1. My purpose is to simulate the transmittance and reflection of Plane wave going through the dielectric material arrays. Does anyone konws how to set the boundary conductions (BCs) on the up and bottom BCs and what does the BCs mean? Also, if I set the left BC to be port 1, which excite TE mode light source, what should the BC for right edge? For the dimensions of the model, what should I set for top, bottom, left and right to get the reasonable results, ie how is the length and width for the yellow air region.
Sorry for so many questions. Any suggestions will be greatly appreciated.
David
7 Replies Last Post 17 feb 2011, 11:37 CET
Posted: 2 decades ago 18 ago 2009, 18:51 CEST
left: add PML(x), and use scattering boundary condition with a source
right: add PML(x), and use scattering boundary condition without a source
top and bottom: PMC
simulation domain: 10 um is enough
Wenshan
left: add PML(x), and use scattering boundary condition with a source right: add PML(x), and use scattering boundary condition without a source top and bottom: PMC simulation domain: 10 um is enough Wenshan
Posted: 2 decades ago 9 set 2009, 21:09 CEST
Hi Wenshan,
I am solving a similar problem and your comments were helpful. I was wondering how do you add both a scattering boundary condition and a port source at the same boundary. Or did you mean define the scattering boundary condition with a source such as a plane wave?
Thank you for your help.
Fatima
Hi Wenshan, I am solving a similar problem and your comments were helpful. I was wondering how do you add both a scattering boundary condition and a port source at the same boundary. Or did you mean define the scattering boundary condition with a source such as a plane wave? Thank you for your help. Fatima
Posted: 1 decade ago 25 nov 2010, 19:14 CET
Hi Wenshan,
I happen to read the reply, I was wondering how to set the "left: add PML(x), and use scattering boundary condition with a source". Could you please tell me?
Regards
Honghui
Hi Wenshan, I happen to read the reply, I was wondering how to set the "left: add PML(x), and use scattering boundary condition with a source". Could you please tell me? Regards Honghui
Posted: 1 decade ago 26 nov 2010, 10:40 CET
Although Wenshan might be able to clarify, until 3.5a it was impossible to have scattering boundaries in the interiors of geoemtry
Posted: 1 decade ago 26 nov 2010, 10:57 CET
I have seen in a paper, they created a domain (not a interior boundary) inside the geometry just beyond one of the PMLs (there are two PMLs in one direction just like the model here), and set this domain as a source to excite the whole calculation domain. I really have no idea how they did this.They did not mention how they did this. Do you have any idea how to do this? or do you know how to add a plane wave source in the interior of a geometry which we can change the incident angle?
Hi, I have seen in a paper, they created a domain (not a interior boundary) inside the geometry just beyond one of the PMLs (there are two PMLs in one direction just like the model here), and set this domain as a source to excite the whole calculation domain. I really have no idea how they did this.They did not mention how they did this. Do you have any idea how to do this? or do you know how to add a plane wave source in the interior of a geometry which we can change the incident angle?
Posted: 1 decade ago 26 nov 2010, 11:33 CET
I know you cannot have practical excitation sources in the interiors of geometry. The most you can have is to specify the electric/magnetic field values in interior boundaries. But that doesn't allow back reflected waves because the field values are fixed which is rarely what you want in your simulations.
And I have no idea about subdomain sources though it shall be interesting to see.
I know you cannot have practical excitation sources in the interiors of geometry. The most you can have is to specify the electric/magnetic field values in interior boundaries. But that doesn't allow back reflected waves because the field values are fixed which is rarely what you want in your simulations. And I have no idea about subdomain sources though it shall be interesting to see.
Posted: 1 decade ago 17 feb 2011, 11:37 CET
Good Evening Sir,
I am doing our thesis on metamaterials.
I am proving the negative refraction of metamaterial.
Can you tell me that how we can check the value of refratcted angle??
Please reply.
Thank you so much for reading my message.
Good Evening Sir, I am doing our thesis on metamaterials. I am proving the negative refraction of metamaterial. Can you tell me that how we can check the value of refratcted angle?? Please reply. Thank you so much for reading my message.
