Re-using physics interface as a study step
In my study I use EMW interface to calculate a set of parameters (let's say, polarization-'p')
and then implement these results in the next step, which uses a different EMW interface.
Schematically:
Step 1(EMW1)--> Step 2 (EMW2(EMW1.p))
Now I'm trying something a bit more complicated, but can't find an elegant way to do so-
I want to calculate the first step twice, each time with one parameter changed (let's call it 'd'), and then implement both results in the same advanced step.
again, schematically:
Step 1(EMW1(d=1)), Step 1(again) (EMW1(d=2)) -->Step 2 (EMW2(EMW1(d=1).p,EMW1(d=2).p))
How can I do that without duplicating the first EMW inteface? (which is done manually, can't find a way to duplicate it automatically)
Can I use Parametric sweep just for one step, and then implement it in the next one? If so, how can I refer to the results in the previous step, and choose which of the results sets to use?
Shay
0 Replies Last Post 3 ago 2014, 14:37 CEST
Hello Shay Keren-Zur
