                                29 mar 2014, 12:30 GMT-4
                                                    How is your question related to COMSOL?
Pu, ZHANG
DTU Fotonik
Pu, ZHANG
DTU Fotonik
                                29 mar 2014, 13:44 GMT-4
                                                    Thanks for your answer :)
I am working on time-dependent simulation where my alpha changes and the value of the integral is used in the next step.  My question is related to COMSOL because the integral has to be evaluated by COMSOL as a part of the model. Hope this helps :)
Cheers
Rokas
Cheers
Rokas
                                29 mar 2014, 14:29 GMT-4
                                                    Does integration coupling variable help?
Pu, ZHANG
DTU Fotonik
Pu, ZHANG
DTU Fotonik
                                29 mar 2014, 15:28 GMT-4
                                                    Can you please elaborate?
                                29 mar 2014, 15:33 GMT-4
                                                    I'm not sure about your particular case. But you can try to search in the documentation or just google it. Actually I think the first google result looks relevant:
www.comsol.com/community/forums/general/thread/15392/
Pu, ZHANG
DTU Fotonik
                            I'm not sure about your particular case. But you can try to search in the documentation or just google it. Actually I think the first google result looks relevant: http://www.comsol.com/community/forums/general/thread/15392/
Pu, ZHANG
DTU Fotonik
                                29 mar 2014, 15:59 GMT-4
                                                    I don't think it is related with my thread. The thing is that I want to integrate not over a time or the coordinate. My integration should be performed independent to somewhat is happening in the model but the integration should be done at every time step. I attached a pdf of the equation I want to implement.
                                29 mar 2014, 17:06 GMT-4
                                                    Isn't it possible to do the integration by yourself...?
Pu, ZHANG
DTU Fotonik
Pu, ZHANG
DTU Fotonik
                                Edgar J. Kaiser
        Certified Consultant
                                29 mar 2014, 17:27 GMT-4
Yes, this integral has a simple analytic solution. You can define it as a simple function into your model.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
                                                    I can do the integration by Matlab, it is not a problem but how to join my values with COMSOL simulation? In this case, my theta comes from Comsol, I do integration in Matlab and then obtain value should be submitted to Comsol and this routine should be performed every step. Is this what you meant?
                                29 mar 2014, 17:29 GMT-4
                                                    Guys, I wrote this function as an example, unfortunately, the real function I use has no analytic solution.
                                29 mar 2014, 17:31 GMT-4
                                                    Then you still can solve it numerically and  use the interpolation option in COMSOL to define the function.
Pu, ZHANG
DTU Fotonik
Pu, ZHANG
DTU Fotonik
                                29 mar 2014, 17:35 GMT-4
                                                    I think that is a brilliant idea :)
                                9 years ago
                                13 giu 2016, 03:39 GMT-4
                                                    have you found a good way to solve the problem in comsol but not use the numerical solution?
