Error message OMP: Warning #2: Cannot open message catalog "1031\libiomp5ui.dll"
After installing Matlab 10a i had some crash. I found a solution and want to post it here for reference.
I am not able to give a minimum example, but the issue may have something to do with several figure windows
and meshgrid/griddata commands.
A cmd window shows up for a few seconds before matlab shuts down.
The cmd window gives an instruction for solving the issue:
Create an environment variable KMP_DUPLICATE_LIB_OK and set it to TRUE
2 Replies Last Post 21 set 2010, 04:52 GMT-4
Hello Stefan Eidelloth
Posted: 2 decades ago 30 apr 2010, 13:51 GMT-4
Thank you, this saved me from a LOT of frustration. The error message came up so quickly, I could never intercept it to find out what it said!
-Kevin Mcilhany
Thank you, this saved me from a LOT of frustration. The error message came up so quickly, I could never intercept it to find out what it said! -Kevin Mcilhany
Posted: 2 decades ago 21 set 2010, 04:52 GMT-4
I am getting the same message (below).
Even a simple line of code( which takes a fraction of a second in normal MATLAB) doesnt now run while using MATLAB with COMSOL.
How do you get aroudn this...
Hi, I am getting the same message (below). Create an environment variable KMP_DUPLICATE_LIB_OK and set it to TRUE Even a simple line of code( which takes a fraction of a second in normal MATLAB) doesnt now run while using MATLAB with COMSOL. How do you get aroudn this...
