To demonstrate a "sieve" at the particle tracing module
Posted 26 feb 2014, 23:14 GMT-5 Charged Particle Tracing, Fluid & Heat, Particle Tracing for Fluid Flow, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 4.3 1 Reply
I expected that the particles bigger than the pore size of the sieve could be filtered and stuck on the sieve surface.
But it seems that the particle tracing module cannot demonstrate such effect because every particle can pass through the pores even which are much smaller than those particles!
Do you think that I have to set up a sort of force equation or "if-condition" which can describe the sieve effect by the size difference??
Thanks!!
Dukwoo
Hello Dukwoo Jun
