Caculate the boundary force through surface integration of von mises stress
Hello everyone , just wanna ask a simple question.
The simulation is performed under structual mechanics.
Geometry is a cone, whose top redius is 0.009um, bottom radius is 5um, height is 9um. Material is silicon.
I applied a boundary load of 1e-6N total force (z direction only) on the top of the cone, and a fixed constraint on the bottom.
I run a stationery study. What I expected is that when I do the surface integration of von mises stress, the calculated force should be more or less 1e-6N, but what I get is 5.8e-9N.
Could anyone tell me what the problem is, please? Thanks a lot.
4 Replies Last Post 20 feb 2014, 17:35 CET
Posted: 1 decade ago 19 feb 2014, 14:44 CET
You should do the surface integration of the stress component normal to the surface, not the Mises stress.
Nagi Elabbasi
Veryst Engineering
You should do the surface integration of the stress component normal to the surface, not the Mises stress. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 20 feb 2014, 16:51 CET
Thanks Nagi
Could you tell me if there is other way to calculate the force?
Thanks Nagi Could you tell me if there is other way to calculate the force?
Posted: 1 decade ago 20 feb 2014, 17:31 CET
Since you apply the load in the Z-direction and I assume you apply it on a surface in the X-Y plane, you should integrate the Z component of the stress tensor.
Posted: 1 decade ago 20 feb 2014, 17:35 CET
I get it. Thanks a lot.
