Problem with Heat Source temperature dependence
Posted 30 dic 2013, 08:44 GMT-5 Heat Transfer & Phase Change Version 4.3b 2 Replies
I am trying to simulate pulsed laser heating of silicon wafer. I am using heat transfer module. My problem is 2-dimensional - my wafer is a cylinder and laser is above the center of it placed perpendicular to the surface, so I use cylindrical coordinates. I use Heat Transfer in Solids physics. I have problem with Heat Source. I want it to be temperature dependent. Here is an expression i would like it to be, but I don't know how to obtain it:
Q(r,z,t)=exp(-integral(alpha,z',0,z))
alpha is an absorption coefficient - material property, which I defined by myself. It is temperature dependent but since in every point of my silicon wafer temperature varies, it makes alpha dependent of spatial coordinates r and z.
alpha = alpha(T(r,z))
In other words after every time step I need alpha to be integrated over z coordinate from 0 to z(respectively for each r and each z) and based on that i want to 'upgrade' my Heat Source Q(r,z,t).
I hope i was clear enough and you guys are able to help me
Andrzej Rudkowski
Andrzej Rudkowski
2 Replies Last Post 14 gen 2014, 04:20 GMT-5
