8 nov 2013, 10:08 CET
Hi All
To make my questions more clear. COMSOL allows to put initial strain/stress . But these options are for selected 3D regions (in the case of 3D problems) . I want to apply initial or external strain only on the top surface of cylinder which is 2D.
Hi All
Nagi Elabbasi
Facebook Reality Labs
8 nov 2013, 22:43 CET
Hi Alberto,
An initial strain in a solid model cannot be confined to the surface with zero thickness. That is I believe a theoretical restriction not a COMSOL restriction. You can create a thin layer close to the surface and apply the initial strain there.
Nagi Elabbasi
Veryst Engineering
Hi Alberto,
Nagi Elabbasi
Veryst Engineering
9 nov 2013, 18:31 CET
Dear Nagi
Thank you for your suggestions. Basically what I wanted is to apply external strain on the top and bottom of the cylinder. I just thought using the initial strain option from COMSOL might bring solution.
As you said it, I can add thin elastic layer but I may change the entire problem. Specially when dealing with core-shell cylinders and piezoelectric cylinders. I jut was wondering if there is direct way in COMSOL to apply external strain on specified surface (Top...bottom....) of the 3D cylinder.
Dear Nagi
