Failing to get ion-current in a microwave plasma
I am using the plasma module mwp in 4.3b. Microwave heated Plasma.
Within this microwave plasma , I want to have a sample on DC bias..
This all looks nice.. but I am not sure I get current out of it?
starting from the library model, adding a metal boundary into the plasma region downstream.
setting its boundary to terminal (applying voltage to it.)
you can only charge it.
adding some circuit, should help.. but even there I have no luck..
the "inplane...where is the current" takes 31 minutes here on a i7..
I have Ion-current and e-current in the mwp.module, but nothing what would flow into the circuit..
why?
Help.
thanks,
Lukas
1 Reply Last Post 2 lug 2013, 05:26 GMT-4
Posted: 1 decade ago 2 lug 2013, 05:26 GMT-4
Now it is working..
but not when I use the Terminal options given by 4.3b ?
I have to define the integrals of the electron and ion currents and to couple "by hand" cir and mwp ..
One step further..
Good feeling..
Frustration level resetted..
Lukas
Now it is working.. but not when I use the Terminal options given by 4.3b ? I have to define the integrals of the electron and ion currents and to couple "by hand" cir and mwp .. One step further.. Good feeling.. Frustration level resetted.. Lukas
