setting mass flow rate at inlet
Model description
I have a 3D laminar air flow inside channel whose cross section is rectangle. for BC ,
1- the inlet , mass flow rate boundary is set (kg/s),
2- the outlet , zero pressure p=0 pa
3- the all other boundaries are symmetry.
My problem:
When I run it, I have a problem with convergence , then eventually failed to find the solution
2 Replies Last Post 17 mag 2017, 17:18 GMT-4
Hello Ahmed Suleiman
Александра Алиева
Posted: 9 years ago 17 mag 2017, 10:05 GMT-4
Updated: 9 years ago 17 mag 2017, 10:06 GMT-4
Hi!
I know that it's the old post, but I'll try to ask, because I have the same problem here. Did you find the solution?
Hi! I know that it's the old post, but I'll try to ask, because I have the same problem here. Did you find the solution?
Posted: 9 years ago 17 mag 2017, 17:18 GMT-4
have you tried to either ramp up the flow, or add some more realistic initial conditions, as some average velocity and Poiseuille first estimate pressure drop across the channel as initial conditions ?
Starting a CFD model with "0" initial conditions and high inlet flow is tricky and not really "physical"
Hi have you tried to either ramp up the flow, or add some more realistic initial conditions, as some average velocity and Poiseuille first estimate pressure drop across the channel as initial conditions ? Starting a CFD model with "0" initial conditions and high inlet flow is tricky and not really "physical" -- Good luck Ivar
