Frequency-Domain, Perturbation
Posted 11 giu 2013, 08:42 GMT-4 Low-Frequency Electromagnetics, Battery Design, Studies & Solvers Version 4.3b 1 Reply
Dear all,
I'm simulating impedance spectra on a newman type lithium ion battery model. I use one single solver Step: Frequency-Domain, Perturbation. There is one single "Electrode Current Densitiy" -node in my model, with the harmonic perturbation option checked.
Everything works fine, the results are the same as with (unbiased) 'manual' time domain calculation.
I'm not sure though, what this Frequency-Domain, Perturbation solver actually does. Results aren't sensitive at all to changes in "Inward electrode current densitiy", the only parameter I can modify here. Only if put in a 0, results are NaN.
Is there a bias? What is the current value in "Inward electrode current densitiy"? If it would be the current bias, a 10C rate should influence the impedance spectrum, but it doesn't.
Thanks for your help.
1 Reply Last Post 14 giu 2013, 10:15 GMT-4
