About Fixed constraint
i have applied fixed constraint (in SM module) at one end of the plate. that is the displacements are zero in all (X,Y,Z)direction. What about rotation? rotation also zero in three direction?
can you explain me
please...
3 Replies Last Post 2 feb 2017, 23:31 CET
Posted: 1 decade ago 12 giu 2013, 10:54 CEST
In a Beam, Shell, or Plate interface, the Fixed condition means that all translations and rotations are zero. In the physics interface having only translational degrees of freedom it means constraining all translations.
Henrik
Hi, In a Beam, Shell, or Plate interface, the Fixed condition means that all translations and rotations are zero. In the physics interface having only translational degrees of freedom it means constraining all translations. Regards, Henrik
Posted: 9 years ago 21 dic 2016, 23:51 CET
but if the problem is a 3D problem like a solid, the rotations with fixed constraint are also equal to zero? in the case that are not zero, which constraint or condition I have to use for that the rotations are equal zero?
excuse my english
but if the problem is a 3D problem like a solid, the rotations with fixed constraint are also equal to zero? in the case that are not zero, which constraint or condition I have to use for that the rotations are equal zero? excuse my english
Posted: 9 years ago 2 feb 2017, 23:31 CET
In a 3D solid analysis, there is no degree of freedom associated with a point's rotations, only its translations. Therefore you cannot directly constrain the rotation of individual points.
In a 3D solid analysis, there is no degree of freedom associated with a point's rotations, only its translations. Therefore you cannot directly constrain the rotation of individual points. Jeff
