3D optical waveguide error
Hello everyone,
What I'm trying to do is basically simulate an optical fiber in 3D. I thought it would be a simple task but I'm running into an error.
I created an optical fibre with an air cladding. The fiber is very thin (.5 um radius).
I thought all I would have to do was create an input port and and exit port, perform a boundary mode analysis on both ports and then add the frequency domain study.
When I do this i get the following error:
Undefined value found.
- Detail: NaN or Inf found when solving linear system using SOR.
Does anyone know what I am doing wrong? Any input would be greatly appreciated.
Thank you,
Mark
6 Replies Last Post 9 lug 2013, 09:32 CEST
Posted: 1 decade ago 10 giu 2013, 18:47 CEST
Which kind of excitation port you are using for this 3D model?
Hi, Which kind of excitation port you are using for this 3D model?
Posted: 1 decade ago 11 giu 2013, 07:43 CEST
I'm using a numeric port. Should I try a user defined port?
Posted: 1 decade ago 18 giu 2013, 06:30 CEST
Is there any way to solve for a field in a 2D model and then import that solution into the 3D model for the boundary mode analysis and then see how it propagates in the 3D model?
Posted: 1 decade ago 19 giu 2013, 11:28 CEST
One last question. I hope someone will answer :)
In the 2D model of a circular optical fiber you can see the modes present. If I make a 3D fiber and only perform a single boundary mode analysis on one input should I be able re recreate the 2D models results? I've tried this with no luck thus far.
Mark
One last question. I hope someone will answer :) In the 2D model of a circular optical fiber you can see the modes present. If I make a 3D fiber and only perform a single boundary mode analysis on one input should I be able re recreate the 2D models results? I've tried this with no luck thus far. Thanks, Mark
Posted: 1 decade ago 9 lug 2013, 06:52 CEST
Hello again,
I've updated to 4.3b and I'm trying a similar model. I think what I have should work but I can't get it to compile.
Could someone take a look at my model and see if there are any obvious mistakes? The solver gets to about 70% but then it stalls for a long time. I think my mesh is correct.
Any advice is welcome!
Mark.
Hello again, I've updated to 4.3b and I'm trying a similar model. I think what I have should work but I can't get it to compile. Could someone take a look at my model and see if there are any obvious mistakes? The solver gets to about 70% but then it stalls for a long time. I think my mesh is correct. Any advice is welcome! Mark.
Posted: 1 decade ago 9 lug 2013, 09:32 CEST
Here is my two cents.
Don't have the RF module so I can't take a look at your model but if the solver stalls, it means there are convergence issues; as the model is quite simple (or it should be) this means something is wrong with the physics.
Here is my two cents. Don't have the RF module so I can't take a look at your model but if the solver stalls, it means there are convergence issues; as the model is quite simple (or it should be) this means something is wrong with the physics.
