Time solver dynamics - advice
Posted 3 giu 2013, 22:05 GMT-4 Low-Frequency Electromagnetics, Studies & Solvers 0 Replies
My problem is solver stability.
Time dependent, direct, mesh = finer. MUMPS.
I am getting variable convergence dynamics simply by setting different _durations_ of the simulation.
Can someone tell me if I get a convergence incident at step X, whether the results for data prior to step X are suspect?
Is the only time I can be confident when the entire simulation is convergence-incident free?
eg...If I truncate a simulation duration just prior to step X, where it previously diverged, why does the new simulaiton move the convergence problem INSIDE the time that was perfectly OK last time?.... and then produce slightly different results (voltages/times)....
confused Colin.
Hello chales
