How to Select the Appropriate Materials from the COMSOL Material Library for Photonics and Liquid Crystal Simulations at 1550 nm?
Dear COMSOL Community,
I am currently pursuing my Ph.D. research in the field of Photonics and Liquid Crystal (LC)-based devices using COMSOL Multiphysics 6.4.
For my simulations, I need to use the following materials:
  1. Silicon (Si)
  2. Silicon Dioxide (SiO₂)
  3. Gold (Au)
  4. E7 Liquid Crystal
  5. Silicon Nitride (Si₃N₄) and so on
My operating wavelength is 1550 nm.
When I use the Add Material option in COMSOL Multiphysics 6.4, I find multiple entries with the same or similar material names. I am unsure which specific material entry I should select for my photonics simulations.
I would appreciate guidance on the following questions:
When multiple entries are available for the same material in the COMSOL Material Library, how can I identify and select the most appropriate one?
Which material properties should I verify before selecting a material for optical simulations at 1550 nm (e.g., refractive index, extinction coefficient, relative permittivity, and wavelength-dependent properties)?
For Silicon, Silicon Dioxide, Gold, and Silicon Nitride, which material data or material models are recommended for photonics applications at 1550 nm?
For E7 liquid crystal, how can I select or define the appropriate anisotropic optical properties, particularly the ordinary refractive index (nₒ), extraordinary refractive index (nₑ), and director orientation along the X-axis or Y-axis?
If the required optical properties are not available in the built-in COMSOL Material Library, should I create custom materials using experimentally reported or literature-based optical constants?
My main objective is to ensure that I select the correct material properties for accurate electromagnetic wave propagation and photonic device simulations at 1550 nm.
I would be grateful for any suggestions, recommendations, or practical examples from experienced COMSOL users.
Thank you.
Reply
