EMAT webinar example reproduction
Hi everyone,
I am trying to reproduce the electromagnetic acoustic transducer example presented in this webinar : https://www.comsol.com/video/modeling-nondestructive-testing-methods-in-comsol-multiphysics I do not have access to the comsol file so I have reproduced the file from the video. The results are not adequate and I do not really know what is causing that : the solid mechanics quantities such as displacement are 0 everywhere. I am not used to multiphysics problems in comsol.
I have attached my file if needed.
Sarah
2 Replies Last Post 10 ott 2026, 07:09 GMT-4
Posted: 1 month ago 9 ott 2026, 21:10 GMT-4
The problem is that your bias magnet isn't magnetic. Try changing the Magnetization Model to Magnetization and set a nonzero magnetization value in the z direction. (There may be better ways to specify this but I don't know EMATs well enough to say).
Posted: 1 month ago 10 ott 2026, 07:09 GMT-4
Hi David,
Thank you very much, that was exactly the problem ! I clearly needed an outside perspective ;) As I was trying to reproduce exactly the tutorial, I followed this way but I also tried using the magnet feature of Magnetic Fields. It works if you disable the magnet feature when computing the frequency domain step.
Sarah
Hi David, Thank you very much, that was exactly the problem ! I clearly needed an outside perspective ;) As I was trying to reproduce exactly the tutorial, I followed this way but I also tried using the magnet feature of Magnetic Fields. It works if you disable the magnet feature when computing the frequency domain step. Sarah
Reply
