Flow electrodes modeling
I want to model a flow electrode where the fluid is a mixture of water and activated carbon with 1M Na2SO4. Can any one help me ? The two electrodes are separated with a nafion 114 membrane.
2 Replies Last Post 30 set 2026, 02:17 GMT-4
Posted: 1 month ago 14 set 2026, 13:33 GMT-4
Hello Shah Mohammed,
Which particular step in the modeling process would you like help with?
Jeff Hiller
Hello Shah Mohammed, Which particular step in the modeling process would you like help with? Best regards, Jeff
Posted: 4 weeks ago 30 set 2026, 02:17 GMT-4
Updated: 4 weeks ago 30 set 2026, 02:26 GMT-4
Thanks a lot for your reply. I need help to select the perfect physics. I have selected Nernst-Planck equation. First problem is in modeling the slurry mixture.
Then, the main problems arises for me to define the ion transport. In a aqueous solution mixed with carbon, how to define the role of carbon during ion transport.
Best regards
Shah Mohammed Takrim
Thanks a lot for your reply. I need help to select the perfect physics. I have selected Nernst-Planck equation. First problem is in modeling the slurry mixture. Then, the main problems arises for me to define the ion transport. In a aqueous solution mixed with carbon, how to define the role of carbon during ion transport. Best regards Shah Mohammed Takrim
Reply
