Efficient Selection of Multiple surfaces as boundaries
Hello everyone,
I’m modeling a system in COMSOL where two rectangular boundary regions must be dynamically moved across a surface, as guided by an optimization algorithm. My current method updates rectangle coordinates on a workplane for each optimization step, but this requires running form union and remeshing every time boundaries change, which is very computationally expensive.
As an alternative, I’m considering pre-generating hundreds of small rectangles on the surface as potential boundary areas. For each optimization iteration, I would simply select subsets of these rectangles to define "terminal" and "ground" regions for electric current physics, without touching the geometry or mesh modules.
To clarify:
Geometry and mesh remain unchanged; only boundary conditions are reassigned among rectangles. I need an efficient way to programmatically select which rectangles to use at each step, ideally automated via MATLAB LiveLink. Currently, I reference rectangles by their surface numbers, which works for a simple test case, but managing hundreds will quickly become unwieldy. I’d like to avoid manually tracking indices.
My main questions:
Is this approach feasible for avoiding repeated form union and remeshing while constantly changing boundary conditions? Is there a robust way in COMSOL to tag or systematically reference large numbers of geometric entities for flexible boundary condition management, especially with MATLAB automation?
I've attached a sample model showcasing this approach, with hundreds of small rectangles and the previous large-rectangle method for reference. For this model, my optimization algorithm will guide me to shit my terminal and based on that I want to select another set of rectangles.
Thank you in advance for any insights!
1 Reply Last Post 4 dic 2025, 15:51 GMT-5
Posted: 9 months ago 4 dic 2025, 15:51 GMT-5
Is it an option the define the boundary settings by an expression, such as
((0.1 < x <0.2) && (0.2 <y < 0.3))*BCsetting
That would define a respective rectangle? You don't need geometry elements this way.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Is it an option the define the boundary settings by an expression, such as ((0.1 < x
