1D-Plot the Deformation of a Line / Edge
Hi again,
I wanna plot the deformation (shape) of an outer edge / line of a 3D-structure before and after applying an external load. The undeformed shape I obtain via a 1D-plot using the expression z over x or the arc-length out of an edge 3d node under results. The displacement I obtain via a 3D-cut line. But how can I obtain the position z over the length x in the deformed state? I´m only able to get the undeformed state. But the information about these coordinates must be available in the results, since the 3D-Plot shows the deformation. Maybe one can use the mesh nodes along that line/edge? Pls give me a hint, I´m dealing with that topic for 4 days now.
BR Sven
4 Replies Last Post 11 set 2025, 16:40 GMT-4
Posted: 1 year ago 11 set 2025, 08:51 GMT-4
Did you try a line plot along this edge and plot the deformation w or w+z along the line?
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Posted: 1 year ago 11 set 2025, 10:15 GMT-4
Hello Edgar,
thanks for the fast reply. Yes I used a line plot in a 1d-plot group to plot the displacement w, which works so far. But I have to mention, that the outer edge is not a straight line but it is curved (crowned). So in fact I need to plot the position of a curved outer edge/line in pristine and deformed state.
BR Sven
Hello Edgar, thanks for the fast reply. Yes I used a line plot in a 1d-plot group to plot the displacement w, which works so far. But I have to mention, that the outer edge is not a straight line but it is curved (crowned). So in fact I need to plot the position of a curved outer edge/line in pristine and deformed state. BR Sven
Posted: 1 year ago 11 set 2025, 10:42 GMT-4
w+z?
Edgar J. Kaiser
www.emphys.com
w+z?
Posted: 1 year ago 11 set 2025, 16:40 GMT-4
Updated: 1 year ago 11 set 2025, 16:45 GMT-4
Hi Edgar,
let me summarize:
at:
Edge-3D & Study1:
  • at z+w(x or arc length), Error caused by w (see picture attached)
  • at z, pristine outer edge contour (crowning) is plotted --> correct values
Cut Line 3D:
  • at w, displacement of the cut line --> plausible
  • at z, pristine position of cut line --> plausible
  • at w+z, --> correct calculation
Sure, from that results it would be possible to calculate the resulting real contour, howsoever.
But why do I always get pristine values for z, for all data sets? How can I obtain deformed position values?
Thanks, Sven
Hi Edgar, let me summarize: at: Edge-3D & Study1: - at z+w(x or arc length), Error caused by w (see picture attached) - at z, pristine outer edge contour (crowning) is plotted --> correct values Cut Line 3D: - at w, displacement of the cut line --> plausible - at z, pristine position of cut line --> plausible - at w+z, --> correct calculation Sure, from that results it would be possible to calculate the resulting real contour, howsoever. But why do I always get pristine values for z, for all data sets? How can I obtain deformed position values? Thanks, Sven
