How to solve a ODE or PDE equation?
Hi~
I try to use COMSOL to solve the mathematical problem.
I have a PDE equation in attachment.
How could I use COMSOL to solve it?
Thank you~
2 Replies Last Post 22 apr 2013, 01:59 CEST
Posted: 1 decade ago 19 apr 2013, 13:25 CEST
1) Creat a new model: Space Dimension 2D, Add Physics-->Mathematics-->Classical PDEs-->Laplace Equiation, Stationary
2)If i understud correctly build a rectangle of Heigth=1 and With=Pi
3)Go to Laplace Equation on the Model Builder, rigth mouse button and creat 2 Dirichlet Boundary Conditions,
4)In the first one select the three boudaries with u=zero
5)In the second one select the lower boundary of the rectangle (the one where the dirichlet condition is non zero) and change the value of the r (for default is set to zero) to 4*cos(6*x/1[m])+ cos(7*x/1[m])
Please let me know if this helps you.
Regards
Hi, 1) Creat a new model: Space Dimension 2D, Add Physics-->Mathematics-->Classical PDEs-->Laplace Equiation, Stationary 2)If i understud correctly build a rectangle of Heigth=1 and With=Pi 3)Go to Laplace Equation on the Model Builder, rigth mouse button and creat 2 Dirichlet Boundary Conditions, 4)In the first one select the three boudaries with u=zero 5)In the second one select the lower boundary of the rectangle (the one where the dirichlet condition is non zero) and change the value of the r (for default is set to zero) to 4*cos(6*x/1[m])+ cos(7*x/1[m]) Please let me know if this helps you. Regards
Posted: 1 decade ago 22 apr 2013, 01:59 CEST
Thanks to Agus~
I upload my file in attachment,.
But how can I verify the result correct with the mathematical answer?
The mathematical answer is also in attachment.
Thank you for help.
Thanks to Agus~ I upload my file in attachment,. But how can I verify the result correct with the mathematical answer? The mathematical answer is also in attachment. Thank you for help.
