Flow between parallel plates
Hey,
I am trying to model flow between 2 parallel plates both of which are moving towards each other. The equations applicable are Continuity and Navier Stokes. However, I am quite not able to find the right interface to model it. Could someone please help me with it....Also, please send any tutorials that could help me solve the problem.
4 Replies Last Post 16 apr 2013, 19:56 CEST
Posted: 1 decade ago 14 apr 2013, 11:46 CEST
check your doc and the "wall" options, there should be a "moving wall option in there ..
Hi check your doc and the "wall" options, there should be a "moving wall option in there .. -- Good luck Ivar
Posted: 1 decade ago 14 apr 2013, 13:11 CEST
hey,
Actually I needed the thickness of the film between the plates too as an output...so I was using the "Thin film Flow interface" to model the flow. So, I have 2 doubts...
Firstly,
Does one require a moving mesh interface to be coupled with Thin film for setting up the study??
Secondly,
How does one specify the velocity of the plates moving towards each other in the displacement field of the Thin film flow interface? I tried displacement =velocity * time but it didn;t quite work out for me....Could you suggest something in this regard?
hey, Actually I needed the thickness of the film between the plates too as an output...so I was using the "Thin film Flow interface" to model the flow. So, I have 2 doubts... Firstly, Does one require a moving mesh interface to be coupled with Thin film for setting up the study?? Secondly, How does one specify the velocity of the plates moving towards each other in the displacement field of the Thin film flow interface? I tried displacement =velocity * time but it didn;t quite work out for me....Could you suggest something in this regard? Thanks :)
Posted: 1 decade ago 16 apr 2013, 14:02 CEST
hey,
I tried building the model with the moving walls option. However, the pressure and velocity profiles are not changing with time in a time dependent study. Could you suggest if something is wrong with the model?
Sarneet
hey, I tried building the model with the moving walls option. However, the pressure and velocity profiles are not changing with time in a time dependent study. Could you suggest if something is wrong with the model? Thanks Sarneet
Mikael Noerregaard Nielsen
Posted: 1 decade ago 16 apr 2013, 19:56 CEST
Hey Sarneet
First of all, I am no expert on the subject but its very hard giving you advice without your model:-) The reason why I mention this is because it could be something in your boundary conditions or perhaps even inlet or outlet conditions.
Best of luck
Regards Mikael
Hey Sarneet First of all, I am no expert on the subject but its very hard giving you advice without your model:-) The reason why I mention this is because it could be something in your boundary conditions or perhaps even inlet or outlet conditions. Best of luck Regards Mikael
