Edgar J. Kaiser
Certified Consultant
6 apr 2013, 09:47 CEST
you are probably running a stationary study. So what the model shows you is the charged up capacitor and the current flow is just determined by the conductivity of the domain between the plates.
If you are interested in the reactivity of the capacitor you must do a time dependent or frequency domain study.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
6 apr 2013, 10:38 CEST
Hi Edgar,
I am actually doing a time dependent analysis but that is only to change the amount of overlap between the plates. So I guess that's true, the capacitor is most likely charged up.
I tried copying the capacitor_transient model which couples EC with CIR and added an additional ALE to change the plate overlap. I think the problem may be that the oscillation time (1/81Hz) is much too long in comparison to the time constant of the RC circuit so it ends up acting like a stationary study and using the conductivity of the air.
Does this mean that EC physics is not appropriate for this type of application or is there something I am missing?
Jeffrey
Hi Edgar,
Jeffrey
6 apr 2013, 11:15 CEST
specifiy if its in EC or ES,
for EC you solve for current this is based on the hypothesis that a little current can flow everywhere, and little is limited by the resultion of binary number max min ratio in conductivity should not exceed 6-8 orders of magnitude (in reality its probably the double, but we cannot represent that correctly with binary number without going to log scale and changing all physics equations accordingly. Anyhow will it really bring us any thing more ? probably not, at least not for >90% of our models
Edgar J. Kaiser
6 apr 2013, 11:28 CEST
It is not clear what your application and what your 'question' to the model is. The beauty of computer models is that you can adapt everything, the frequency, the circuit, whatever ....
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
[QUOTE]
[/QUOTE]
Cheers
Edgar
Edgar J. Kaiser
