29 mar 2013, 09:03 CET
I would rather say it's not that COMOSL doesnt support that solver set-up, but rather that COMSOL cannot decide "automatically" how to solve such coupled physics without that you end user decides how you want to couple the physics.
One can also categorise the physics after their order of time derivatives, Solid as ACDC RF and other have 2nd order time derivatives and are of the type "wave equations" you can imagine sustained standing waves. But diffusion type equations (including HT) are rather 1st order in time or arranged such that you cannot have "standing waves".
What one have to decide in a case of joule dissipation (ACDC) and heat equation (HT) is how to couple them, as HT act, in the frequency domain a an extremely "low pass filter" (not fully true in MEMS size due the surface to volume ratio) so normally one solves with two solvers, a frequency domain (or stationary and harmonic excitation) for the ac (respectively DC+ac) current EC and a time dependent transient, or stationary for the HT part, by using the RMS value of the frequencya domain solver results as loads.
So far I have noticed that "pre-cooked" multihysics in COMSOL are mixed in such that you do not split up the solver sequences when setting up your solver methodology (except for a few cases).
So to make the long stor much shorter: set up your model with separate physics, then you decide how to couple and the granularity of the interaction, it comes to the same as the multi-physics case, but with a bit more clicks, and it forces you to think really over how these physics interact, in your case.
But check carefully and validate the results as it's very easy to miss some couplings, when working in this way, just as when using multiphyiscs, the coupling hypothesis used might not be the way you intendend !
