Backward Problem
Posted 19 mar 2013, 07:35 GMT-4 Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 4.2a 0 Replies
I like to scale a given heatflux distribution to reach a maximum temperature in a domain.
If I know the location where I expect this max. temperature, I can do this via a global equation: f(T-Tmax) to obtain a scaling variable qscale for the heat flux distribution and an integration operator: Tmax=intop(T) specified at the point where I want to reach the temperature Tmax.
But what if I don't know the location of Tmax in the domain?
If I exchange the integration operator intop with a maximum operator maxop on the domain I get:
Failed to find a solution.
Singular matrix.
There are 1 void equations (empty rows in matrix) for the variable mod1.qscale
at coordinates: (0,0), ...
Can this issue be solved without the optimization module ?
Thank you very much for any help.
______
Flanell
Hello Flanell
