Study inside Study
Posted 28 mag 2025, 20:36 GMT-5 Electromagnetics, Studies & Solvers, Modeling Workflow Version 6.3 2 Replies
Hi everyone, I need some help with a multiphysics simulation in COMSOL. I'm working on a model that involves two main studies:
-A time-dependent study, where certain material properties (permittivity and conductivity) evolve over time according to a time-dependent variable.
-A frequency domain study, where I want to evaluate the capacitance of the system based on the state of the material at each time step from the time-dependent study.
My goal is to: Run a time-dependent simulation (e.g., from 0 to 6000 hours, with 1000-hour intervals). At each time step, perform a frequency-domain analysis (using a fixed excitation frequency). Extract the capacitance at a specific point in the excitation cycle (e.g., the peak of a square wave).
However, I'm running into issues: The material properties used in the frequency domain study seem to stay fixed rather than update based on the time-dependent solution. As a result, the capacitance result doesn’t change between time steps. I tried using the “Values of variables not solved for” field to specify the correct times, but I get errors like "parameter mismatch" or the solver just doesn't progress.
My question: How can I configure COMSOL so that the frequency domain study is evaluated at each time step of the time-dependent study, using the updated material properties from that time?
Thanks in advance for any tips!
