27 feb 2013, 07:58 CET
do you have some "air / vacuum around your wave-guide?
I do remember from previous simulations that the PML worked better when they surrounded a all air domain
28 feb 2013, 19:48 CET
3 things are important:
1. enough mesh elements in the PML
2. same material for PML and the domain it touches
3. change PML type to General if you want to change PML scaling factor and other parameters manually
1 mar 2013, 16:53 CET
Thank you for the suggestions.
I haven’t used any air/ vacuum my system is a waveguide Silicone (n=3.4) as core between silica (n=1.45) and water (n=1.33) as claddings.
I split the PML in to 3 for each material in my system so that the PML and the materials match.
I have used a sweep mesh for the PML from the interface of the Materials and the PML with 10 elements. But I am still getting some back reflections?
When you said change the PML to general for manual scaling is it in version 4.3 ? I didn’t see an option to do that in the definition node.
1 mar 2013, 21:05 CET
It's in the settings for PML. Geometric Settings, Type: General
[QUOTE]
[/QUOTE]
2 mar 2013, 09:11 CET
then I have a question, if we have different materials, and we split up the PML accordingly to have the "same material" what about oblique vaves hitting the interface in the PML region, would that scatter ?
What is best, set all air around and PML air, or remove the air for large INF domains, and split the PML and give material properties ?
Have fun COMSOLing
Have fun COMSOLing
4 mar 2013, 16:39 CET
then I have a qusion, if we have different mateials, and we split up the PML accordingly to have the "same material" what about oblique vaves hitting the interface in the PML region, would that scatter ?
I haven't seen the back-scattering at such interfaces. Sometimes there is a "surface wave" going along this interface. But seems like scattering BC outside of PML takes care of it.
I never set up air all around.For the simulations I do, it won't represent the correct structure. But I guess it should work in antenna-type simulations just fine.
[QUOTE]
[/QUOTE]
[QUOTE]
[/QUOTE]
4 mar 2013, 20:38 CET
Thanks for your comments ;)
11 mar 2013, 12:30 CET
Dear All
thanks allot for these information, i also simulate the silicon wave guide: brillouin scattering ( interaction between the pump and Stoke waves), i used the PML to prevent the reflection in the wave guide, but still i can not get the scattered wave because i do not know how to simulate the Stoke wave and get the acoustic mode. I used the RF electromagnetic and elastic wave modules.
please any suggestions and if you want i will attach my Comsol file.
Best Regards
Dear All
Best Regards
