Computing View Factor
Hello, I have performed simulations of surface-to-surface radiation using solar and ambient settings to account for the wavelength dependence of the radiative properties. I would like to verify the view factor between two surfaces. I have already obtained great information from this: https://www.comsol.com/blogs/computing-view-factors-with-the-heat-transfer-module, being able to verify the view factors for the constant wavelength dependence of the radiative properties using the rad.radopd and rad.radopu operators. I tried to do the same using the operators rad.radopB1u or rad.radopB2u but always got an unknown operator error message. I have also tried using a different syntax based on the definition of other variables within COMSOL getting the same result. I thank in advance anyone who can help me solve this problem.
Many thanks and kindest,
Aniello
1 Reply Last Post 4 mar 2025, 16:12 GMT-5
Walter Frei COMSOL Employee
Posted: 2 years ago 4 mar 2025, 16:12 GMT-5
Hello Aniello,
The names of these operators have changed since that was written, they are: rad.radopu1(Ju, Jd) rad.radopd1(Ju, Jd) rad.radopu2(Ju, Jd) rad.radopd2(Ju, Jd)
Hello Aniello, The names of these operators have changed since that was written, they are: rad.radopu1(Ju, Jd) rad.radopd1(Ju, Jd) rad.radopu2(Ju, Jd) rad.radopd2(Ju, Jd)
