Inconsistent uni-directional constraint with Conjugate Heat transfer
I am trying to model a simple high temperature hydrogen heat exchanger with the conjugate heat transfer module. While I have been sucessfull in modeling individual tubes of the hydrogen alone, I cannot seem to get a model with multiple tubes working.
In this model, half of a 3 tube heat exchanger is modeled with the outer shell excluded. A temperature dependent heat flux (temperature dependent as it takes into account radiation losses) is applied to the outer wall of the model. Symmetry is used to reduce computational time. While a custom mesh is used here, the comsol generic mesh was also tried. My mesh significantly reduces the memory used and allows for a much better distribution of resolution however.
For this model, I used the results from my single tube model of the hydrogen to provide the initial results. The text files include in the zipped folder consist of the data for these functions. All of the functions used here are to input these results as the initial conditions of the hydrogen.
For some reason, I continuously get the error "Inconsistent uni-directional constraint". I assume this means there is some error in the coupling of the heat transfer and fluid flow physics, but exactly what that is I have no idea. In addition to using the conjugate heat transfer module I have also tried manually coupling heat transfer in fluids and low Re turbulent flow modules but I get the same error. Does anyone have any ideas?
3 Replies Last Post 17 dic 2013, 16:26 CET
Hello Dan Gould
Posted: 1 decade ago 28 ott 2013, 04:55 CET
HI
I'm getting the same error when I'm running a problem with floquet Boundary conditions.
Anybody has any idea what " Inconsistent uni-directional constraint " error means?
HI I'm getting the same error when I'm running a problem with floquet Boundary conditions. Anybody has any idea what " Inconsistent uni-directional constraint " error means?
Posted: 1 decade ago 17 dic 2013, 11:23 CET
I also met this problem with Floquet periodic BC usually. Sometimes a slight altering of mesh can solve this. But this unpredictable error are still annoying when doing batch simulations since you don't know when it will show!!
Jim Freels mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
Posted: 1 decade ago 17 dic 2013, 16:26 CET
If you are using k-e turbulence models, you should be OK. I have had similar warning messages, so I asked COMSOL tech support back on 12/2010 (3 years ago now). Here is the response I received at that time:
"The k-e formulation is using so called non-ideal constraints. These are
nonlinear and can result in local inconsistencies. This is to be expected
and result in merging of the constraints. We have not yet been able to
pinpoint this sort constraint handling from other cases where this is not
expected, therefore a warning is printed.
A user can for example setup non-ideal constraints that are inconsistent
and merging/removing these without a warning can be rather misleading since
the returned solution can then not fulfill the constraints."
My results have been good, so I have ignored this message with my solutions.
If you are using k-e turbulence models, you should be OK. I have had similar warning messages, so I asked COMSOL tech support back on 12/2010 (3 years ago now). Here is the response I received at that time: "The k-e formulation is using so called non-ideal constraints. These are nonlinear and can result in local inconsistencies. This is to be expected and result in merging of the constraints. We have not yet been able to pinpoint this sort constraint handling from other cases where this is not expected, therefore a warning is printed. A user can for example setup non-ideal constraints that are inconsistent and merging/removing these without a warning can be rather misleading since the returned solution can then not fulfill the constraints." My results have been good, so I have ignored this message with my solutions.
