Lars Gregersen
COMSOL Employee
2 years ago
5 dic 2024, 04:31 GMT-6
Updated:
2 years ago
5 dic 2024, 07:31 GMT-6
There are a few issues.
When using LiveLink for MATLAB all coordinates are in column format. I.e. you have to use coord' instead of coord.
You have to specify the dataset. I assume for this model dset9 makes sense.
For these type of components you have to specify that you want to evaluate on domains.
This should work:
T = mphinterp(model, 'T', 'coord', coord','dataset','dset9','edim','domain')
Note that the expression can be any valid COMSOL expression not just a variable or field name. I recommend that you open the COMSOL GUI (using the command mphlaunch) and find some expressions to use there.
Lars Gregersen
Comsol Denmark
This should work:
2 years ago
5 dic 2024, 11:20 GMT-6
Updated:
2 years ago
5 dic 2024, 13:02 GMT-6
Hi Lars,
Thanks for the quick respond. I am still learning Livelink functions and how to edit and extract the information/results via ML. Your line worked perfectly, I was playing a bit to extract velocity values and I created a new dataset/study/selection and selected the flow domain for the velocity and it worked too for a point and cutline.
Hi Lars,
