Using geometry values in physics boundary conditions
Hi all,
I have tried to look around but have not figured out a way to do this. I would like to use a geometry value (i.e. the surface area of an ellipsoid) to define the flux boundary condition through that ellipsoid. For simple structures I can calculate this by hand but it never seems to come out right in comsol in the results... it would be nice to do this within comsol for when the geometry gets more complicated and to eliminate this error. More specifically, I have a total flux in number of molecules per second, but the boundary condition in comsol only accepts mol/m^2s. If my flux is say, 500 molecules per second, I would like to be able to put say '500 / boundary area' as my flux. Suggestions?
2 Replies Last Post 4 feb 2013, 19:37 GMT-5
Posted: 1 decade ago 4 feb 2013, 19:25 GMT-5
Figured out (partially) how to do what I wanted. Realized that you can set up integral functions in the definitions section of a model that can be used in all parts of the model. So now I am doing a surface integral over my area and dividing as desired. However, I am not getting the answer that I expect to get and I am not sure if this is due to rounding or other errors in COMSOL or some fundamental problem.
For flux I am using:
300[1/s]/6.02e23[1/mol]/intop1(1)
where intop1 is the surface integral over the boundary releasing molecules.
However, when I solve the model, if I then integrate flux over the same boundary, and multiply by avogadros constant, I get 252molecules/s instead of the 300/second that I would expect based on the formula that I entered.
Figured out (partially) how to do what I wanted. Realized that you can set up integral functions in the definitions section of a model that can be used in all parts of the model. So now I am doing a surface integral over my area and dividing as desired. However, I am not getting the answer that I expect to get and I am not sure if this is due to rounding or other errors in COMSOL or some fundamental problem. For flux I am using: 300[1/s]/6.02e23[1/mol]/intop1(1) where intop1 is the surface integral over the boundary releasing molecules. However, when I solve the model, if I then integrate flux over the same boundary, and multiply by avogadros constant, I get 252molecules/s instead of the 300/second that I would expect based on the formula that I entered.
Posted: 1 decade ago 4 feb 2013, 19:37 GMT-5
Looks like the result gets more accurate the more I refine the mesh, which makes sense, since the intop1 value will be an analytical result over a perfect ellipsoid and the model result will be an ellipsoid mapped with triangular elements. I am looking for a way now to locally refine the mesh (it's a 3d model) only around the ellipsoid. Is there a way to do this?
