density of arrows in contact forces can't be controlled
Posted 25 set 2024, 07:42 GMT-7 13 Replies
When there's contact in solid mechanics simulation, there's an automatic node "contact forces" in results. There are Contact 1, Pressure and Contact 1, Friction Force nodes under this node. The density of the arrows (pressure and friction) under these two nodes can't be controlled, as when clicking "uniform" in arrow positioning, no arrow is plotted. Gauss points is the only option but the downside of doing so is that the arrows are too dense if the mesh is fine. How to overcome?
The contact forces are shown using a standard Arrow Surface plot. So it has all possible settings for controlling arrow placement and density.
-------------------Henrik Sönnerlind
COMSOL
thanks but as the attached picture, it looks different from an arrow surface plot
There is no attached picture?
-------------------René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
there seems to be a problem. I tried very hard with different browsers but failed to attach the picture.
Posting this for OP.
Acculution ApS
www.acculution.com
info@acculution.com
Trying again
Acculution ApS
www.acculution.com
info@acculution.com
Okay, I don't know how to upload pictures here either, sorry.
Acculution ApS
www.acculution.com
info@acculution.com
Dr Christensen thanks so much! Can any forum admin help? There must be a bug with uploading pictures. It used to work!
The problem has been reported to the IT team.
COMSOL
has this IT issue been resolved?
Picture upload test: Enjoy!
It is often much easier and faster to test things rather than waiting for a forum response. And it is obvious that some people had been uploading pictures very recently.
-------------------Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
please check this attached picture related to my question
Pictures and screenshots are mostly not very useful. Consider to post the model.
www.emphys.com
Suggested Content
- KNOWLEDGE BASE Controlling the Time Dependent Solver Timesteps
- KNOWLEDGE BASE Structural Contact Modeling Guidelines
- FORUM Gravity Forces
- BLOG How to Use the Load Plots in Structural Analyses
- FORUM electrostatic forces
