Acculution ApS
Certified Consultant
12 months ago
19 set 2024, 09:24 CEST
It would not be a 2D-axisymmetric problem, if you revolve it into a surface in 3D space. But you can make a 3D component, draw your 2D geometry on a work plane, and then revolve that.
If it is only for post-processing, you can extrude/revolve a 2D-axi solution into a surface plot.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
12 months ago
19 set 2024, 18:57 CEST
Thank you for the reply, but the first question really was if in 2D I can build a surface starting from a the list of its sides.
Robert Koslover
12 months ago
23 set 2024, 15:59 CEST
Have you considered applying a conversion operation? I'm not sure if this is the same thing as what you are talking about, but if you have a set of connected line segments, arcs, etc., in 2D, then in the Model Builder, right-click on Geometry, then click on Conversions, then Convert to Solid. Select your objects (the segments and arcs) and build.
Have you considered applying a conversion operation? I'm not sure if this is the same thing as what you are talking about, but if you have a set of connected line segments, arcs, etc., in 2D, then in the Model Builder, right-click on *Geometry*, then click on *Conversions*, then *Convert to Solid*. Select your objects (the segments and arcs) and build.
11 months ago
24 set 2024, 07:52 CEST
Ok, I was not clear on the solid part. It took a few attempts but I think it worked. Thank you.
