Adding damping layer in COMSOL
Posted 12 set 2024, 10:20 CEST 0 Replies
HI, I also wanna model a damping layer (constrained and unconstrained layer) located to the outer boundary of turbine tower with a specific length (L) along the height of tower (I will do a parametric sweep of L). The problem is that the cylinder is tapered hence I can't easily model the geometry which should be attached to the outer boundary of the tower. I saw I could use linear layer model in the shell physics but the mesh is not computed. Which is the easiest way to do it and more suitable for my case.
Hello Filippo Tosato
