Manipulating data from tables
Hi all,
I'm working on a model using piezodevice physics in the frequency domain, and I'm trying to plot admittance in dB (rather than siemen). I've found the admittance by taking the surface integral of the current density (pzd.JZ) over one of the electrodes, which results in a table with admittance values for each frequency. Is there any way to apply additional mathematical manipulation to the values in that table? To convert to dB, I need to take 10*log10(x) for each admittance value. I've tried doing the 10*log10(abs(pzd.JZ)) as the expression in the surface integral, but that doesn't work... though admittedly my math is a little fuzzy as to why not.
It seems like there must be an easy way to manipulate data in a table, but I can't seem to find it. Any advice would be greatly appreciated!
Jillian
1 Reply Last Post 26 gen 2013, 01:08 CET
Posted: 1 decade ago 26 gen 2013, 01:08 CET
I believe you should take the 10*log10( integration_of(...)) (or is it 20* ? amplitude or power) but you are applying the integration_of(10*log10(whatever)) this is not the same thing
Then dB is normally a ratio based on some value 1mW, 1m ... 1uPa
Only easy way around you define a variable as My_var = 10*log10( intop1(whatever)), and then plot the global variable My_var
or perhaps dB are in the units for your table (but which normalisation ? I expect not to find the dB there
Hi I believe you should take the 10*log10( integration_of(...)) (or is it 20* ? amplitude or power) but you are applying the integration_of(10*log10(whatever)) this is not the same thing Then dB is normally a ratio based on some value 1mW, 1m ... 1uPa Only easy way around you define a variable as My_var = 10*log10( intop1(whatever)), and then plot the global variable My_var or perhaps dB are in the units for your table (but which normalisation ? I expect not to find the dB there -- Good luck Ivar
