Henrik Sönnerlind
COMSOL Employee
2 years ago
15 mag 2024, 05:31 GMT-5
If you just want a sliding, no-rotation constraint, you can use a Symmetry condition. There, you can also select if the boundary has a true roller condition, or is allowed to translate in the perpendicular direction.
Henrik Sönnerlind
COMSOL
If you just want a sliding, no-rotation constraint, you can use a **Symmetry** condition. There, you can also select if the boundary has a true roller condition, or is allowed to translate in the perpendicular direction.
2 years ago
15 mag 2024, 11:54 GMT-5
Updated:
2 years ago
15 mag 2024, 11:58 GMT-5
hello Henrik Sönnerlind,
Thank you very much for your response I Have a question.
For the system I don't want any sliding i just want it to be able to move in all direction (x y and z) but not able to rotated in the x y and z( the result im looking for is in this image) for the Symmetry condition does putting a free displacement work?
Henrik Sönnerlind
COMSOL Employee
2 years ago
20 mag 2024, 07:41 GMT-5
Using Free displacement in Symmetry will give you almost what you want. But there is still one rotation that is allowed then. The best option to constrain all three rotations is probably to use a Rigid Connector with the flexible formulation.
Henrik Sönnerlind
COMSOL
2 years ago
20 mag 2024, 17:29 GMT-5
hello one more question
what is flexible formulation on rigid connector?
Magnus Ringh
COMSOL Employee
2 years ago
21 mag 2024, 01:09 GMT-5
Hi Nelson,
In the Settings window for a Rigid Connector, you can choose, under Connection Type, Rigid or Flexible. Choose Flexible for the flexible formulation, which is useful, for example, when applying loads because it will reduce local constraint effects.
Magnus
Hi Nelson,
In the **Settings** window for a **Rigid Connector**, you can choose, under **Connection Type**, **Rigid** or **Flexible**. Choose **Flexible** for the flexible formulation, which is useful, for example, when applying loads because it will reduce local constraint effects.
Magnus
2 years ago
21 mag 2024, 12:56 GMT-5
Updated:
2 years ago
22 mag 2024, 07:27 GMT-5
Once i add the rigid connector on the boundary to constrain rotation in x y and z direction, do I need to add another boundary condition on the same place as the rigid connector to not allow to rotate or the rigid connector is equal to a no-rotation constraint.
Thank you very much.
Henrik Sönnerlind
COMSOL Employee
2 years ago
22 mag 2024, 03:42 GMT-5
You only set Constrained rotation in the Prescribed Rotation section of the Rigid Connector settings, and select all three checkboxes.
Henrik Sönnerlind
COMSOL
You only set **Constrained rotation** in the **Prescribed Rotation** section of the **Rigid Connector** settings, and select all three checkboxes.
2 years ago
22 mag 2024, 10:39 GMT-5
thanl you very much I check this out to see if this work.
