20 dic 2012, 08:12 CET
Check the Forum, it has been discussed several times ;) you can obtain such "pulses" by combining the step or rect with an analytical function, you have also the advance make periodic options tab to play with
9 years ago
9 ott 2016, 18:01 CEST
I went through the posts in
www.comsol.com/community/forums/general/thread/2924
where pulse train has been discussed in good detail. Thank you.
However,
In using COMSOL Analytic function with mod(t, value)
where value is less than 0.05 I am getting a straight horizontal line as output.
My pulse width (On time) is in micro seconds and would like to get 100 microsecond pulse width for 200 ms period.
Is it not possible to use mod function in this case ?
PS: I am unable to find "reply" option in the previous discussion thread,
I went through the posts in https://www.comsol.com/community/forums/general/thread/2924
However,
Jeff Hiller
COMSOL Employee
9 years ago
10 ott 2016, 14:12 CEST
Hello AJ,
Using mod is not recommended. Instead, see my post in this thread:
www.comsol.com/community/forums/general/thread/103901/
Hello AJ,
https://www.comsol.com/community/forums/general/thread/103901/
9 years ago
11 ott 2016, 02:03 CEST
Hello Jeff ,
I am unable to give a On time (pulse width) of 100 microseconds.
I see only options of angular frequency and smoothing can be changed.
How do I change the pulse width (on time) ?
I am using rect() . it does not accept microsecond range. It gives a straight line. for values less than 0.0055
with 100 microsecond pulse and getting 100 pulses for a seconds seems to be not working when I try to plot by Jeff's method.
Is it a graphical limitation ?
I can get only upto 13 pulses in a second. not more than that
Hello Jeff ,
