Current/Charge conservation in AC/DC
My model has several layers of domains having different conductivity and permittivity. I want current to be conserved in each domain independently. At present, I choose current conservation node for respective domains.
After solving, the volume integration of space charge denisty on all domains (i.e. the net charge) is zero. However, each domain is not independently conserved. Is there a way to specify independent charge or current conservation to each domain?
Arun
1 Reply Last Post 10 dic 2012, 10:40 CET
Posted: 1 decade ago 10 dic 2012, 10:40 CET
from my understanding, one or several current conservation nodes does not separate the items, by default all internal boundaries are in "continuation mode". If you want to have "isolation between the domains, you need either to use assembly mode, or probably easier add electrical isolation / shielding between your layers on the BC's
Hi from my understanding, one or several current conservation nodes does not separate the items, by default all internal boundaries are in "continuation mode". If you want to have "isolation between the domains, you need either to use assembly mode, or probably easier add electrical isolation / shielding between your layers on the BC's -- Good luck Ivar
