multiple rigid bodies with independent properties in the "rigid domain/material" node
Posted 25 gen 2024, 04:32 GMT-6 Modeling Tools & Definitions, Structural Mechanics, Modeling Workflow Version 6.1 2 Replies
Hi everyone!
Using Structural Mechanics Interface, I am wondering if there is an option for specifying the independence of multiple rigid bodies within the "rigid domain/material" node? I found that if you selected all the objects in one node, they will behave simultaneously with the same responses.
For less number of objects, I can create the same number of rigid domain/material nodes to ensure their independent responses. But for a huge quantity of rigid bodies, such as 100, manually setting up is not feasible...
Is there an option in rigid domain/material node to set up the independence of multiple objects , or a way to speed up the manual configuration process more efficiently? Thank you!
