Fail to simulate 2 physics together
I am trying to simulate a model which has both solid mechanics and magnetic field modules. I can simulate two physics seperately, but every time they are connected, an error returns:
Segregated group 1
Failed to evaluate variable Jacobian.
- Variable: mod1.curlAz
- Geometry: 1
- Domain: 1
Here I attached a simple coupled model. Could anyone help me with it? Thanks
1 Reply Last Post 27 nov 2012, 16:56 CET
Posted: 1 decade ago 27 nov 2012, 16:56 CET
COMSOL support solved this problem:
The error is caused by a conflict in the handling of frames. The physics
interfaces in Comsol can be usually solved either in a Solid material
("Material" frame) or in a Non-solid material ("Spatial" frame).
Electromagnetic interfaces are however an exception, since they require a
special treatment in presence of deformations (for example, Lorentz
currents must be added to moving conductors).
Therefore, in the current version, the electromagnetic interfaces require
that the "Material type" setting is consistent in all the features (either
Solid or Non-solid) and with the frame selected in the physics node.
In your model, it is sufficient to change the Material type in Ampère's
Law to Non-solid.
COMSOL support solved this problem: The error is caused by a conflict in the handling of frames. The physics interfaces in Comsol can be usually solved either in a Solid material ("Material" frame) or in a Non-solid material ("Spatial" frame). Electromagnetic interfaces are however an exception, since they require a special treatment in presence of deformations (for example, Lorentz currents must be added to moving conductors). Therefore, in the current version, the electromagnetic interfaces require that the "Material type" setting is consistent in all the features (either Solid or Non-solid) and with the frame selected in the physics node. In your model, it is sufficient to change the Material type in Ampère's Law to Non-solid.
