Particle trajectory simulation - spiral microfluidic
Posted 31 ott 2023, 22:25 GMT-4 Microfluidics, Particle Tracing for Fluid Flow, Studies & Solvers 0 Replies
Hello! I am currently designing a spiral microchip for CTC isolation from blood sample. I tried doing the particle trajectory simulation but the isolation failed and as I checked the velocity field is not centered. Anyone knows why? Is it because I input the wrong velocity?
Here is the image https://drive.google.com/file/d/1JfrJY1HwwcwRhZVqAZHOxTkGgqs73W19/view?usp=sharing
The dimension of the chip is as follow: -Height: 110 mikrom -Width: 500 mikrom -Inner circle: 9 cm -Outer radius: 12 cm -Turns: around 1.75
Meanwhile the inlets are seperated in a size of 1:2
I put in a velocity of 2 for the smaller inlet and 3 for the bigger one
Please let me know how to estimate the right velocity in a spiral microfluid.
Here is the mph file, its too big for me to upload so i put it in gdrive for you to download. https://drive.google.com/file/d/1O4ko-5aOt6mbtVktTwGil9ZV1wk_X8-N/view?usp=sharing
Hello Yeseniya Dameria
