Acculution ApS
Certified Consultant
9 months ago
15 ago 2023, 04:22 GMT-4
There are many ways to define coordinate systems under Definitions, so it should be possible to find one that can fit with your coil setup.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
9 months ago
11 set 2023, 06:20 GMT-4
Thank you for your reply, I didn't notice it earlier . This answer is helpful to me.
I created two electromagnets that are facing each other side by side. And I want to calculate the force on one electromagnet due to the other one. But I am getting negative force when the the moving coil is moving toward the stationary one.
Now I am thinking that the electromagnet design itself is wrong, because the magnetic fiels line are not supposed to be the way in wanted them to flow .
What is the approach I should follow for this problem ?
