                                4 nov 2012, 11:32 GMT-5
yes FSI is one possibility, acoustic probably another (I do not have that one) but if you want frequency domain analysis then FSi does not works, as the physics is not set up for that solver type
                                4 nov 2012, 13:48 GMT-5
thanks for your answer,now i know that FSI don’t support  frequency domain  analysis,in other way could  i do time dependent anlysis  then convert it  to frequency domain?
Kai
Kai
                                4 nov 2012, 14:49 GMT-5
you cannot convert a time domain to frequency domain, but you can excite a time domain with a Ampl*sinus(2*pi*freq*t), but that takes a long time as you need to run the time solver for many steps per periode, and you need to have good initial conditions to avoid any ringing transients. But I agree it is possible.
On the other hand, to add the fliud load, normally that should be doable via the acoustic, and in the frequency domain, but ti's just that I do not have access to that module so I have not managed to try it nor validate it
                                6 nov 2012, 13:49 GMT-5
                            This may meet your requirements:
www.comsol.com/showroom/gallery/1477/
