Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
2 years ago
28 giu 2023, 21:48 CEST
Lorenso, it coud be several things including meshing and method of solution depending on your material properties if nonlinear features are added. Also, confused on a 2D axisymmetric model of a spherical geometry. If willing, please attach a sample .mph file, and we might be able to diagnosis better. One suggestion that always holds true is to gradually increase your "load"; especially if you experience problems in converence as you are. The load in this case sounds like the heat addition. For example, you might try a zero heat load to start to make sure you get a steady state equal to the initial state when you solve. That is always a good test. Then perhaps gradually increase the load, and suggest parametric sweep to do that automatically, until you reach the desired heat load. One thought is that the laminar flow (low flow rate implied) may not be sufficient to remove the heat load.
James D. Freels, Ph.D., P.E.
Jeff Hiller
COMSOL Employee
2 years ago
28 giu 2023, 22:33 CEST
Updated:
2 years ago
29 giu 2023, 14:56 CEST
Hello Lorenzo,
I second James's suggestion that you post your mph file. With that said, if you have a constant heat flux going into a sphere with no way for that heat to leave the system, there is no steady state solution to that problem, and no stationary solver can, nor should, converge.
Jeff Hiller
Hello Lorenzo,
