24 ott 2012, 15:08 CEST
the COMSOL RF module contains the far field calculations. You have to include a 'far field calculations' node into the model. This is available under the RF physics node. In the far field node you must define the boundary that serves as input for the far field calculations. This can be a sphere around your antenna, possibly the inner sphere of a PML.
This makes the far field variables available for post processing.
But take care: 3D far field post processing takes a lot of time, sometimes more than solving the model. If you restrict it to 2D, such as the typical polar azimuth and elevation diagrams you are fine, they are quick. Please note: the model can still be 3D, just the post processing should be 2D.
Cheers
Edgar
Cheers
Edgar
24 ott 2012, 15:22 CEST
Cheers
Edgar
Thank you very much for your response. Yes, I need 2D plot.
Just to be clear, you say that if I want to plot radiation pattern I have to put Far Field domain BEFORE simulation?
But can you give me some advice with this. It is not so complicated to put all equations for far filed domain when I have antenna in air free space. But problem is my antenna is on substrate, so I am not sure how to make sphere on which I have to do far field calculations. Is it possible to make sphere which is one half in the air, one half in glass?
In any case thanks on first response.
Best regards
[QUOTE]
Cheers
Edgar
[/QUOTE]
Best regards
24 ott 2012, 17:19 CEST
Yes, you must define the far field domain before running the model. Otherwise you don't get the variables.
Regarding the substrate, I must admit I don't know. I would expect the model will run with a hetrogeneous far field domain. You will need to check the results for plausibility with a simple case. Maybe the dipole is well suited for that.
Cheers
Edgar
Cheers
Edgar
24 ott 2012, 18:42 CEST
Thank you very much on answer.
Regards
Regards
