how to load the temperature field to an block as the body resource load?
I want to simulate the defect detection process on the Al block using the laser-ultrasound,and I don't know how to load the temperature field to an block as the body load.Hoping for help,thanks very much!
4 Replies Last Post 23 ott 2012, 09:45 CEST
Posted: 1 decade ago 23 ott 2012, 07:30 CEST
what do you mean to load the temperature as a "body load", do you want to fix the temperature ? ir is it the initial value of the temperature ?, If you have a thermal process fixing the body temperature is not really physical, but if you fix it on its borders + initial conditions, and no thermal process will take place then it will remain at that initial temperature
Hi what do you mean to load the temperature as a "body load", do you want to fix the temperature ? ir is it the initial value of the temperature ?, If you have a thermal process fixing the body temperature is not really physical, but if you fix it on its borders + initial conditions, and no thermal process will take place then it will remain at that initial temperature -- Good luck Ivar
Posted: 1 decade ago 23 ott 2012, 08:58 CEST
I want to load the temperature field as body resource,like the pressure on the block,but i don't know how to realize this.Are there any models in the model liberary?
[QUOTE] Hi what do you mean to load the temperature as a "body load", do you want to fix the temperature ? ir is it the initial value of the temperature ?, If you have a thermal process fixing the body temperature is not really physical, but if you fix it on its borders + initial conditions, and no thermal process will take place then it will remain at that initial temperature -- Good luck Ivar [/QUOTE] I want to load the temperature field as body resource,like the pressure on the block,but i don't know how to realize this.Are there any models in the model liberary?
Posted: 1 decade ago 23 ott 2012, 09:13 CEST
Define it in the initial conditions, that should do ;)
Hi Define it in the initial conditions, that should do ;) -- Good luck Ivar
Posted: 1 decade ago 23 ott 2012, 09:45 CEST
thanks for your reply
