uniform current in a volume
Hi I have a problem of circular coil. I have added uniform current to it. I can see this current is only in the center of coil, not spread uniformly in its volume. I want to model uniform cuurent in whole volume. If anyome can tell, what are the relevant settings or what's wrong with my model. I have attached it too.
4 Replies Last Post 2 mag 2023, 16:31 GMT-4
Posted: 3 years ago 1 mag 2023, 13:13 GMT-4
I ran your model. The current density does not exhibit that behavior, if you look closely. (Try plotting a slice plot of the current density in a plane that bisects the loop.) Also, you might want to use a finer mesh on that coil, since in your model, nearly the entire cross-section of the wire is being represented by a single mesh element.
Posted: 3 years ago 1 mag 2023, 17:59 GMT-4
Thanks Robert Now, I got it.
>I ran your model. The current density does not exhibit that behavior, if you look closely. (Try plotting a slice plot of the current density in a plane that bisects the loop.) Also, you might want to use a finer mesh on that coil, since in your model, nearly the entire cross-section of the wire is being represented by a single mesh element. Thanks Robert Now, I got it.
Posted: 3 years ago 2 mag 2023, 15:22 GMT-4
Hi Robert I want to know how can I get current density vector that exists in any finite element? I have 2D axisymmetric version of same problem where only phi component of magnetic vector potential exists, r and z are zero. But in 3D model there are all three, though r and z are small. I believe the current density vector can only be near to phi direction, has r component. But z must be zero. I have attached 2D axisymmetirc version of same problem where it is visible that A has only phi component. Can you explain, why in 3D the other two components of A are also present. (I have applied vector transformation to A in 3D and looking for A at inner surface of infinite domain).
>>I ran your model. The current density does not exhibit that behavior, if you look closely. (Try plotting a slice plot of the current density in a plane that bisects the loop.) Also, you might want to use a finer mesh on that coil, since in your model, nearly the entire cross-section of the wire is being represented by a single mesh element. > >Thanks Robert >Now, I got it. Hi Robert I want to know how can I get current density vector that exists in any finite element? I have 2D axisymmetric version of same problem where only phi component of magnetic vector potential exists, r and z are zero. But in 3D model there are all three, though r and z are small. I believe the current density vector can only be near to phi direction, has r component. But z must be zero. I have attached 2D axisymmetirc version of same problem where it is visible that A has only phi component. Can you explain, why in 3D the other two components of A are also present. (I have applied vector transformation to A in 3D and looking for A at inner surface of infinite domain).
Posted: 3 years ago 2 mag 2023, 16:31 GMT-4
You may be seeing numerical effects. To find out, see if the values change (for the small but non-zero components of A) if you use a finer mesh.
