Mads Herring Jensen
COMSOL Employee
17 ott 2012, 09:51 CEST
Hi Kevin
This model is alreaddy in Comsol, if you select "pressure acoustics, frequency domain" and then set the fluid model to "Biot equivalent" and the "Porous matrix approximation" to Rigid. It is exactly the "Johnson Champoux Alard model". Have a look at the equation doisplay or the documentation.
Best regards
Mads
Hi Kevin
Best regards
Mads
3 mar 2014, 22:06 CET
Hi Mads,
I have similar problem as Kevin and I am a new comsol user. How can I set the fluid model to "Biot equivalent" and the "Porous matrix approximation" to Rigid?
Hi Mads,
Mads Herring Jensen
COMSOL Employee
3 mar 2014, 22:58 CET
Hi Abdoulkadri
In older versions of COMSOL go to the Pressure Acoustics domain node and then select the fluid model "Biot equivalent" (the default selected is Linear Elastic) and the "Porous matrix approximation" to Rigid? You need the Acoustics Module for this.
In COMSOL 4.4 the Johnson-Champaux-Allard (JCA) model has moved to the new Poroacoustics domain feature. Here you can directly select the JCA or Delany-Bazley-Miki.
Hi Mads,
Hi Abdoulkadri
[QUOTE]
Hi Mads,
[/QUOTE]
8 mar 2014, 18:26 CET
Hi Mads,
what I am doing is oscillatory test in the poroelastic media. During the process, the biot theory is applied.
(1) My question is how to apply a boundary load on the top of the poroelastic sample in frequency domain. It seems the corresponding displacement is a complex value rather than real value. But my displacement is real value.
(2) If the bounary load is a step stress, what can I do to apply a boundary load. Most of samples in 4.4 is in frequency.
If you can not understand what I mean, I'd like to upload my 'mph'
Hi Mads,
Linus Andersson
COMSOL Employee
10 mar 2014, 08:35 CET
Hi Chenghao!
Please send your model mph-file along with your questions to support@comsol.com. We will help you from there!
Linus
Hi Chenghao!
Linus
