9 ott 2012, 21:04 CEST
it could be that you do not have enough BC and/or initial conditions and that COMSOL is "oscillating" between two valid solutions.
Normally the solver is made to only work for a fully defined system with ONE solution
10 ott 2012, 09:14 CEST
I'm shure I have enough boundary conditions regarding my PDE's.
And shouldn't I further than expact the whole solution to be oscillating and not only the region at the boundaries?
10 ott 2012, 13:24 CEST
that depends have you tried to change the mesh density, if you oscilalte with the mesh (turn off the smoothing under quality) then there is a fair chance that you have 2 valid solutions and COMSOL cannot decide or alternates, between both.
Or you might change a littleyour initial conditions / BCs and you can then perhaps select one or the other.
ut there might be other issues too ;)
10 ott 2012, 16:48 CEST
I turned off the smoothing, which didn't change the solution at all. I'll simply define a fine mash at the boundaries and hope it will be fine enough to solve the oscillations there.
Thanks anyway
Thanks anyway
11 ott 2012, 07:10 CEST
the postprocessing smoothen doesnt change the solution, at best it reveals the "true" calculated points and hiding some artefacts one can obtain in poorly meshed regions (w.r.t. dependent variable and their gradients)
To improve the solution, one must identify the true issue and solve that, but often it comes from meshing issues as this is the "model sampling" used for the calculations. Think of time signal sampling (music) if you want to get the correct tone and pitch, you need to sample up to the Nyquist criteria, and if posible better, with the mesh it's similar, you nee to sample correctly the dependent variables and at to resolve least their first derivative , the gradients
