About The Time Step Setting Of The Solver
About The Time Step Setting Of The Solver(stat,step,stop),I have the following questions.If there will be any answers, I will be very grateful. (1)Can the time step setting of the transient solver be set to multiple ranges? (2)There is a transient period in my life that I don't need to see. How do I need to transition? It can be set to a larger step value to skip this time period? (3)Must the start value of the next range be equal to the stop value of the previous range? Can the stat value of the next range greater than the stop value of the previous range? Will this affect the results and accuracy of the transient process. The first of my two processes is the microsecond level, the second is the second level .“range (0,2.18E-4, 2.18E-3), range (1,1,16)” Can I set it like this? (4)The settings under the“Transient Solver 1 ” .There are two options for "defined by research steps": user-defined, and step 1: transient. Is this to be modified to user-defined?
2 Replies Last Post 15 mar 2023, 09:28 CET
Posted: 2 years ago 12 mar 2023, 19:51 CET
The specification range(t0,dt,tf) is equivalent to a list of time values. For the calculation to make sense the time values need to be monotonic.
I don't know what happens if you REPEAT time values in the list but (1) I can't see why you would do this and (2) it probably isn't good.
The specification range(t0,dt,tf) is equivalent to a list of time values. For the calculation to make sense the time values need to be monotonic. I don't know what happens if you REPEAT time values in the list but (1) I can't see why you would do this and (2) it probably isn't good.
Posted: 2 years ago 15 mar 2023, 09:28 CET
Thank you.
>The specification range(t0,dt,tf) is equivalent to a list of time values. For the calculation to make sense the time values need to be monotonic. > >I don't know what happens if you REPEAT time values in the list but (1) I can't see why you would do this and (2) it probably isn't good. Thank you.
