Time dependent simulation
Dear Sir,
I am trying to model an energy harvester in which discrete pressures must be applied one after the other. The pressure applied is not continuous but varying values of pressure is applied one after the other in short succession.
On the whole , a varying values of pressure are applied to the energy harvester and it must produce varying values of voltage continuously , as long as pressure is applied.
I found that even 'Time Dependent' study does not give a provision to model such a situation. It would be of great help if you can guide me through the steps involved.
Thanking you in advance,
Vijay
2 Replies Last Post 1 ott 2012, 21:47 CEST
Posted: 1 decade ago 1 ott 2012, 16:02 CEST
You can implement some analytic but discontinuous functions, as:
deltap*floor(t/deltat), where deltap and deltat are increments in pressure and time, respectively, and t is the time;
1*(x>=0)*(x<=10)+5*(x>10)*(x<=15)+7*(x>15)*(x<=30), where the functions is 1 for x in (0,10], 5 for x in (10, 15] and 7 for x in (15,30].
Bye.
Jesus.
Hello, You can implement some analytic but discontinuous functions, as: deltap*floor(t/deltat), where deltap and deltat are increments in pressure and time, respectively, and t is the time; 1*(x>=0)*(x10)*(x15)*(x
Posted: 1 decade ago 1 ott 2012, 21:47 CEST
yes bolean functions is one way, but they are not derivable so often the solver has problems to converge over the steps. You can also get steps by using the default step functions that are "smoothed such to make them derivable and continuous over the steps.
Steps also make a system ring if you have inertial terms on, in time series analysis you might also have conversion issues when using a too low damping
Hi yes bolean functions is one way, but they are not derivable so often the solver has problems to converge over the steps. You can also get steps by using the default step functions that are "smoothed such to make them derivable and continuous over the steps. Steps also make a system ring if you have inertial terms on, in time series analysis you might also have conversion issues when using a too low damping -- Good luck Ivar
